ArcGIS.Desktop.Mapping Namespace / LasPointClassBreaksRendererDefinition Class / ModulateUsingIntensity Property
Example
    ModulateUsingIntensity Property (LasPointClassBreaksRendererDefinition)
    Gets or sets the flag indicating whether or not to modulate using intensity. The default value is false.
    Syntax
    Public Property ModulateUsingIntensity As Boolean
    public bool ModulateUsingIntensity {get; set;}
    Example
    LAS Points Classified Elevation Renderer
      var lasPointsClassBreaksRendererDef = new LasPointClassBreaksRendererDefinition();
      lasPointsClassBreaksRendererDef.ClassificationMethod = ClassificationMethod.NaturalBreaks;
      lasPointsClassBreaksRendererDef.ModulateUsingIntensity = true;
      // increase the symbol size by a factor
      lasPointsClassBreaksRendererDef.SymbolScaleFactor = 1.0;
      // Note: Needs QueuedTask to run
        if (lasDatasetLayer.CanCreateRenderer(lasPointsClassBreaksRendererDef))
          CIMTinRenderer renderer = lasDatasetLayer.CreateRenderer(lasPointsClassBreaksRendererDef);
          if (lasDatasetLayer.CanSetRenderer(renderer, SurfaceRendererTarget.Points))
            lasDatasetLayer.SetRenderer(renderer, SurfaceRendererTarget.Points);
    Requirements
    ArcGIS Pro version: 3.2 or higher.
