ArcGIS.Desktop.Mapping Namespace / LasPointClassBreaksRendererDefinition Class / SymbolScaleFactor Property
Example
    SymbolScaleFactor Property (LasPointClassBreaksRendererDefinition)
    The symbol scale factor. Default value is 0.0.
    Syntax
    Public Property SymbolScaleFactor As Double
    public double SymbolScaleFactor {get; set;}
    Remarks
    The symbol scale factor is applied to the symbols. The symbol size is calculated as Math.Pow(2, symbolSizeFactor). Valid values are between -4.0 and 4.0.
    Example
    LAS Points Classified Elevation Renderer
      var lasPointsClassBreaksRendererDef = new LasPointClassBreaksRendererDefinition();
      lasPointsClassBreaksRendererDef.ClassificationMethod = ClassificationMethod.NaturalBreaks;
      lasPointsClassBreaksRendererDef.ModulateUsingIntensity = true;
      // increase the symbol size by a factor
      lasPointsClassBreaksRendererDef.SymbolScaleFactor = 1.0;
      // Note: Needs QueuedTask to run
        if (lasDatasetLayer.CanCreateRenderer(lasPointsClassBreaksRendererDef))
          CIMTinRenderer renderer = lasDatasetLayer.CreateRenderer(lasPointsClassBreaksRendererDef);
          if (lasDatasetLayer.CanSetRenderer(renderer, SurfaceRendererTarget.Points))
            lasDatasetLayer.SetRenderer(renderer, SurfaceRendererTarget.Points);
    Requirements
    ArcGIS Pro version: 3.2 or higher.
