ArcGIS.Desktop.Mapping Namespace / ITablePane Interface
Members Example
    Interface to the table pane.
    Object Model
    ITablePane InterfaceMapMember Class
    Syntax
    public interface ITablePane
    Public Interface ITablePane
    Example
    Set zoom level for Attribute Table
      //Check if the active pane is an ITablePane
      if (FrameworkApplication.Panes.ActivePane is ITablePane tablePane)
        //Get the current zoom level of the table pane
        var currentZoomLevel = tablePane.ZoomLevel;
        // Set a new zoom level, for example, increase it by 50
        var newZoomLevel = currentZoomLevel + 50;
        // Set the new zoom level to the table pane
        tablePane.SetZoomLevel(newZoomLevel);
    Retrieve the values of selected cell in the attribute table
          var mapMember = tablePane.MapMember;
          //Get the active row's object ID from the table pane
          var oid = tablePane.ActiveObjectID;
          if (oid.HasValue && oid.Value != -1 && mapMember != null)
            //Get the field of the active column
            var activeField = tablePane.ActiveColumn;
            await QueuedTask.Run(() =>
              // TODO: Use core objects to retrieve record and get value
    Move to a particular row
      // Check if the active pane is an ITablePane
        // move to first row
        tablePane.BringIntoView(0);
        // move to sixth row
        tablePane.BringIntoView(5);
    Change table View caption
      // find all the table panes (table panes hosting map data)
      var tablePanes = FrameworkApplication.Panes.OfType<ITablePane>();
      var tablePane = tablePanes.FirstOrDefault(p => p is ITablePaneEx { Caption: "oldCaption" });
      if (tablePane is ITablePaneEx tablePaneEx)
        tablePaneEx.Caption = "newCaption";
      // find all the external table panes (table panes hosting external data)
      var externalPanes = FrameworkApplication.Panes.OfType<IExternalTablePane>();
      var externalTablePane = externalPanes.FirstOrDefault(p => p.Caption == "oldCaption");
      if (externalTablePane != null)
        externalTablePane.Caption = "newCaption";
    Get TableView from table pane
      var tablePane = tablePanes.FirstOrDefault(p => p is ITablePaneEx { Caption: "caption" });
        tableView = tablePaneEx.TableView;
      // if it's not found, maybe it's an external table pane
      if (tableView == null)
        var externalTablePane = externalPanes.FirstOrDefault(p => p.Caption == "caption");
          tableView = externalTablePane.TableView;
    Requirements
