ArcGIS.Desktop.Mapping Namespace / LineOfSightResult Class
Members Example
    A class to contain the results of running SurfaceLayer.GetLineOfSight
    Object Model
    LineOfSightResult ClassPolyline ClassMapPoint ClassPolyline Class
    Syntax
    Public Class LineOfSightResult
    public class LineOfSightResult
    Remarks
    The output line of sight is divided into visible and invisible portions along the input sight line running from the LineOfSightParams.ObserverPoint to the LineOfSightParams.TargetPoint.
    Example
    Get Line of Sight
      tinLayer = null;
      MapPoint observerPoint = null;
      MapPoint targetPoint = null;
      CIMPointSymbol obstructionPointSymbol = null;
      CIMLineSymbol visibleLineSymbol = null;
      CIMLineSymbol invisibleLineSymbol = null;
      var losParams = new LineOfSightParams();
      losParams.ObserverPoint = observerPoint;
      losParams.TargetPoint = targetPoint;
      // add offsets if appropriate
      // losParams.ObserverHeightOffset = observerOffset;
      // losParams.TargetHeightOffset = targerOffset;
      // add obstruction feature class if appropriate (multipatch)
      //losParams.ObstructionsMultipatchFeatureClass = obsFeatureClass;
      // set output spatial reference
      losParams.OutputSpatialReference = MapView.Active.Map.SpatialReference;
      LineOfSightResult results = null;
      try
        // Note: Needs QueuedTask to run
          if (tinLayer.CanGetLineOfSight(losParams))
            results = tinLayer.GetLineOfSight(losParams);
      catch (Exception)
        // handle exception
      if (results != null)
        bool targetIsVisibleFromObserverPoint = results.IsTargetVisibleFromObserverPoint;
        //These properties are not used. They will always be false
        // results.IsTargetVisibleFromVisibleLine;
        // results.IsTargetVisibleFromInvisibleLine;
        if (results.VisibleLine != null)
          MapView.Active.AddOverlay(results.VisibleLine, visibleLineSymbol.MakeSymbolReference());
        if (results.InvisibleLine != null)
          MapView.Active.AddOverlay(results.VisibleLine, invisibleLineSymbol.MakeSymbolReference());
        if (results.ObstructionPoint != null)
          MapView.Active.AddOverlay(results.ObstructionPoint, obstructionPointSymbol.MakeSymbolReference());
    Inheritance Hierarchy
    System.Object
       ArcGIS.Desktop.Mapping.LineOfSightResult
    Requirements
    ArcGIS Pro version: 3.2 or higher.
