ArcGIS.Desktop.Mapping Namespace / TinBreaklineRendererDefinition Class / TinBreaklineRendererDefinition Constructor / TinBreaklineRendererDefinition Constructor()
Example
    Creates a breakline renderer definition.
    Syntax
    Public Function New()
    public TinBreaklineRendererDefinition()
    Example
    Create a TerrainLayer with renderers
      var terrainCP_renderers = new TerrainLayerCreationParams(terrain);
      terrainCP_renderers.Name = "My LAS Layer";
      terrainCP_renderers.IsVisible = true;
      // define the edge type renderer - use defaults
      var edgeRD = new TinBreaklineRendererDefinition();
      // define the face/surface renderer
      var faceRD = new TinFaceClassBreaksRendererDefinition();
      faceRD.ClassificationMethod = ClassificationMethod.NaturalBreaks;
      // accept default color ramp, breakCount
      // define the dirty area renderer - use defaults
      var dirtyAreaRD = new TerrainDirtyAreaRendererDefinition();
      // add renderers to dictionary
      var t_dict = new Dictionary<SurfaceRendererTarget, TinRendererDefinition>();
      t_dict.Add(SurfaceRendererTarget.Edges, edgeRD);
      t_dict.Add(SurfaceRendererTarget.Surface, faceRD);
      t_dict.Add(SurfaceRendererTarget.DirtyArea, dirtyAreaRD);
      // assign dictionary to creation params
      terrainCP_renderers.RendererDefinitions = t_dict;
      // Note: Needs QueuedTask to run
        //Create the layer to the terrain
        var terrainLayer_rd = LayerFactory.Instance.CreateLayer<TerrainLayer>(terrainCP_renderers, map);
    Edge Type Renderer
      var breaklineRendererDef = new TinBreaklineRendererDefinition();
      // use default symbol for regular edge but specific symbols for hard,soft,outside
      breaklineRendererDef.HardEdgeSymbol = hardEdgeSymbol.MakeSymbolReference();
      breaklineRendererDef.SoftEdgeSymbol = softEdgeSymbol.MakeSymbolReference();
      breaklineRendererDef.OutsideEdgeSymbol = outsideEdgeSymbol.MakeSymbolReference();
        if (surfaceLayer.CanCreateRenderer(breaklineRendererDef))
          CIMTinRenderer renderer = surfaceLayer.CreateRenderer(breaklineRendererDef);
          if (surfaceLayer.CanSetRenderer(renderer, SurfaceRendererTarget.Edges))
            surfaceLayer.SetRenderer(renderer, SurfaceRendererTarget.Edges);
    Requirements
    ArcGIS Pro version: 3.2 or higher.
