ArcGIS.Desktop.Mapping Namespace / TinContourRendererDefinition Class / ContourFactor Property
Example
    Gets or sets the contour factor. The default value is 5.
    Syntax
    Public Property ContourFactor As Integer
    public int ContourFactor {get; set;}
    Example
    Contour Renderer
      var contourDef = new TinContourRendererDefinition();
      // now customize with a symbol
      contourDef.Label = "Contours";
      contourDef.SymbolTemplate = contourLineSymbol.MakeSymbolReference();
      contourDef.ContourInterval = 6;
      contourDef.IndexLabel = "Index Contours";
      contourDef.IndexSymbolTemplate = indexLineSymbol.MakeSymbolReference();
      contourDef.ContourFactor = 4;
      contourDef.ReferenceHeight = 7;
      // Note: Needs QueuedTask to run
        if (surfaceLayer.CanCreateRenderer(contourDef))
          CIMTinRenderer renderer = surfaceLayer.CreateRenderer(contourDef);
          if (surfaceLayer.CanSetRenderer(renderer, SurfaceRendererTarget.Contours))
            surfaceLayer.SetRenderer(renderer, SurfaceRendererTarget.Contours);
    Requirements
    ArcGIS Pro version: 3.2 or higher.
