ArcGIS.Desktop.Core Namespace / ArcGISPortalExtensions Class / GetUserContentAsync Method
the username
optional folderid
Example
    Gets the given username's content. Items are either in the home folder for the user, e.g. /content/users/{username} or in a subfolder of the home folder with the given folder ID. Multilevel folders are not supported.
    Syntax
    Public Shared Function GetUserContentAsync( _
       ByVal portal As ArcGISPortal, _
       ByVal username As String, _
       Optional ByVal folderId As String _
    ) As Task(Of PortalUserContent)
    public static Task<PortalUserContent> GetUserContentAsync(
       ArcGISPortal portal,
       string username,
       string folderId
    Parameters
    portal
    username
    the username
    folderId
    optional folderid
    Return Value
    Exceptions
    ExceptionDescription
    Thrown when an invalid portal is provided as the active portal.
    username cannot be null or empty.
    You must be signed on to get user content.
    You do not have permissions to access this resource or perform this operation.
    Request failed: status code {status code}.
    Remarks
    Executes the following portal rest query:
    {portalURL}sharing/rest/content/users/{userName}
    or {portalURL}sharing/rest/content/users/{userName}/{folderId} if a folderid was provided. Users executing this query must be signed on or an exception will be thrown.
    Example
    Workflow to open an ArcGIS Pro project
      projectPath = @"https://<userName>.<domain>.com/portal/sharing/rest/content/items/1a434faebbe7424d9982f57d00223baa";
      string docVer = string.Empty;
      // A portal project path looks like this:
      //@"https://<ServerName>.<Domain>.com/portal/sharing/rest/content/items/1a434faebbe7424d9982f57d00223baa";
      //A local project path looks like this:
      //@"C:\Users\<UserName>\Documents\ArcGIS\Projects\MyProject\MyProject.aprx";
      //Check if the project can be opened
      if (Project.CanOpen(projectPath, out docVer))
        //Open the project
        Project.OpenAsync(projectPath);
      else //The project cannot be opened
        //One possible reason: If the project is a portal project, the active portal must match the portal of the project
        //Check if this is a portal project
        bool isPortalProject = Uri.TryCreate(projectPath, UriKind.Absolute, out Uri uriResult)
             && (uriResult.Scheme == Uri.UriSchemeHttp || uriResult.Scheme == Uri.UriSchemeHttps);
        if (isPortalProject)
          //Parse the project path to get the portal
          var uri = new Uri(projectPath);
          var portalUrlOfProjectToOpen = $"{uri.Scheme}://{uri.Host}/portal/";
          //Get the current active portal
          var activePortal = ArcGISPortalManager.Current.GetActivePortal();
          //Compare to see if the active Portal is the same as the portal of the project
          bool isSamePortal = activePortal != null && activePortal.PortalUri.ToString() == portalUrlOfProjectToOpen;
          if (!isSamePortal) //not the same.
            //Set new active portal to be the portal of the project
            //Find the portal to sign in with using its Uri...
            var projectPortal = ArcGISPortalManager.Current.GetPortal(new Uri(portalUrlOfProjectToOpen, UriKind.Absolute));
            // Note: Needs QueuedTask to run
              if (!projectPortal.IsSignedOn())
                //Calling "SignIn" will trigger the OAuth popup if your credentials are
                //not cached (eg from a previous sign in in the session)
                if (projectPortal.SignIn().success)
                  //Set this portal as my active portal
                  ArcGISPortalManager.Current.SetActivePortal(projectPortal);
                  return;
            //Now try opening the project again
            else
              System.Diagnostics.Debug.WriteLine("The project cannot be opened.");
          else //The portals are the same. So the problem could be something else - permissions, portal is down?
        else //Project is on disk and cannot be opened.
    Retrieve a project item from a portal and open it
      var projectPortal = ArcGISPortalManager.Current.GetPortal(new Uri(@"https://<serverName>.<domain>.com/portal/", UriKind.Absolute));
      string owner = string.Empty;
        //Get the signed on user name
        owner = projectPortal.GetSignOnUsername();
      //Get the user content from the portal
      PortalUserContent userContent = projectPortal.GetUserContentAsync(owner).Result;
      //Get the first portal project item
      var firstPortalProject = userContent.PortalItems.FirstOrDefault(pi => pi.PortalItemType == PortalItemType.ProProject);
      var portalProjectUri = firstPortalProject.ItemUri.ToString();
      //Check if project can be opened
      if (Project.CanOpen(portalProjectUri, out docVer))
        Project.OpenAsync(portalProjectUri);
      //Note: If Project.CanOpen returns false, the project cannot be opened. One reason could be
      // the active portal is not the same as the portal of the project. Refer to the snippet: [Workflow to open an ArcGIS Pro project](ProSnippets-sharing#workflow-to-open-an-arcgis-pro-project)
    Portal: Get the user content for the active user from the active portal
      var owner = activePortal.GetSignOnUsername();
      var activeUserContent = await activePortal.GetUserContentAsync(owner);
      //Get content for a specific folder (identified by its folder id)
      //var userContent = await portal.GetUserContentAsync(owner, folderId);
      //Get all the folders
      foreach (var pf in userContent.PortalFolders)
        //Do something with the folders
      //Get all the content items
      foreach (var pi in userContent.PortalItems)
        //Do something with the portal items
    Portal: Download any package items in the user content
      var packages = new List<PortalItemType>
        PortalItemType.BasemapPackage,
        PortalItemType.GeoprocessingPackage,
        PortalItemType.LayerPackage,
        PortalItemType.LocatorPackage,
        PortalItemType.MapPackage,
        PortalItemType.ProjectPackage,
        PortalItemType.ScenePackage,
        PortalItemType.RulePackage,
        PortalItemType.VectorTilePackage
      var folder = @"E:\Temp\PortalAPITest\";
      //Get the UserContent - refer to the initialization section above for more details
      foreach (var di in userContent.PortalItems.Where(pi => packages.Contains(pi.PortalItemType)))
        var path = System.IO.Path.Combine(folder, di.Name);
        await di.GetItemDataAsync(path);
    Requirements
