ArcGIS.Desktop.Mapping Namespace / TinNodeRendererDefinition Class / TinNodeRendererDefinition Constructor / TinNodeRendererDefinition Constructor()
Example
    Creates a simple renderer definition to draw nodes in a surface layer.
    Syntax
    Public Function New()
    public TinNodeRendererDefinition()
    Example
    Create a TinLayer with renderers
      var tinCP_renderers = new TinLayerCreationParams(tinDataset)
        Name = "My TIN layer",
        IsVisible = true
      // define the node renderer - use defaults
      var node_rd = new TinNodeRendererDefinition();
      // define the face/surface renderer
      var face_rd = new TinFaceClassBreaksRendererDefinition();
      face_rd.ClassificationMethod = ClassificationMethod.NaturalBreaks;
      // accept default color ramp, breakCount
      // set up the renderer dictionary
      var rendererDict = new Dictionary<SurfaceRendererTarget, TinRendererDefinition>
      { SurfaceRendererTarget.Points, node_rd },
      { SurfaceRendererTarget.Surface, face_rd }
      // assign the dictionary to the creation params
      tinCP_renderers.RendererDefinitions = rendererDict;
      // Note: Needs QueuedTask to run
        // create the layer
        var tinLayer_rd = LayerFactory.Instance.CreateLayer<TinLayer>(tinCP_renderers, MapView.Active.Map);
    Simple Node Renderer
      // applies to TIN layers only
      var nodeRendererDef = new TinNodeRendererDefinition();
      nodeRendererDef.Description = "Nodes";
      nodeRendererDef.Label = "Nodes";
      nodeRendererDef.SymbolTemplate = nodeSymbol.MakeSymbolReference();
        if (tinLayer.CanCreateRenderer(nodeRendererDef))
          CIMTinRenderer renderer = tinLayer.CreateRenderer(nodeRendererDef);
          if (tinLayer.CanSetRenderer(renderer, SurfaceRendererTarget.Points))
            tinLayer.SetRenderer(renderer, SurfaceRendererTarget.Points);
    Requirements
    ArcGIS Pro version: 3.2 or higher.
