ArcGIS.Desktop.Mapping.Geocoding Namespace / LocatorManager Class / GeocodeAsync Method / GeocodeAsync(String,Boolean,Boolean,Boolean) Method
The address/location to geocode.
Should the candidate results be displayed on the active map?
Should the map zoom to the first candidate result?
Set to true to show a cancelable message box
    Perform a geocode operation. Geocode results are returned according to the active locator providers.
    Syntax
    Parameters
    location
    showResultsOnMap
    zoomToFirstResult
    showCancelPrompt
    Return Value
    Task of List of GeocodeResult objects. If no locators can be found then null is returned.
    Remarks
    If showCancelPrompt is set to true then, if GeocodeAsync is called when a previous geocode has not completed, a message box prompt asking the user if they wish to cancel the current (i.e. "previous") geocode will be shown that must be acknowledged. If showCancelPrompt is set to false no message box is shown.
    Requirements
    ArcGIS Pro version: 3.2 or higher.
