ArcGIS.Desktop.Workflow.Client.Models Namespace / INotificationManager Interface / UnsubscribeFromJobs Method
The ids of the jobs to subscribe to
Example
    Unsubscribe to messages for the given jobs
    Syntax
    Sub UnsubscribeFromJobs( _
       ByVal jobIds As List(Of String) _
    void UnsubscribeFromJobs(
       List<string> jobIds
    Parameters
    jobIds
    Example
    QueuedTask.Run(() => { var jobIds = new List() { "123456789", "234567890" }; // When unsubscribing from jobs, use the same instance of NotificationManager used to subscribe to jobs. notifMgr.SubscribeToJobs(jobIds); });
      // Unsubscribe from the job message event using the subscription token
      JobMessageEvent.Unsubscribe(subscriptionToken);
      // Unsubscribe from jobs using the same instance of Notification Manager used to subscribe to jobs.
      // This will remove the jobs from the subscribed job list if no other clients are subscribed to those jobs.
      var notifManager = WorkflowClientModule.NotificationManager;
      notifManager.UnsubscribeFromJobs(jobIds);
    Requirements
    ArcGIS Pro version: 3.2 or higher.
