ArcGIS.Core.Geometry Namespace / GeometryBag Class / ToEsriShape Method / ToEsriShape(Byte[]) Method
The buffer to which the geometry will be written. The buffer must be large enough to hold the Esri shapefile formatted version of the input geometry.
    Converts this GeometryBag into an Esri shape formatted binary byte buffer and returns the size of the shapeBuffer.
    Syntax
    Public Overloads Overrides NotOverridable Function ToEsriShape( _
       ByRef shapeBuffer() As Byte _
    ) As Long
    public override long ToEsriShape(
       ref byte[] shapeBuffer
    Parameters
    shapeBuffer
    Return Value
    The number of bytes used to store this instance in the input shapeBuffer.
    Exceptions
    ExceptionDescription
    The method is not implemented for GeometryBag.
    Requirements
