ArcGIS.Core.Data Namespace / StatisticsFunction Enumeration
Example Example
    Specifies the statistics function to be performed.
    Syntax
    Members
    MemberDescription
    Average The average function.
    Count The count function.
    Max The maximum function.
    Min The minimum function.
    StandardDeviation The standard deviation function.
    Sum The sum function.
    Example
    Calculating Statistics on a Table
      // Must be called within QueuedTask.Run
      // Calculate the Sum and Average of the Population_1990 and Population_2000 fields, grouped and ordered by Region
      void CalculateStatistics(FeatureClass countryFeatureClass)
        using (FeatureClassDefinition featureClassDefinition = countryFeatureClass.GetDefinition())
          // Get fields
          Field regionField = featureClassDefinition.GetFields()
            .First(x => x.Name.Equals("Region"));
          Field pop1990Field = featureClassDefinition.GetFields()
            .First(x => x.Name.Equals("Population_1990"));
          Field pop2000Field = featureClassDefinition.GetFields()
            .First(x => x.Name.Equals("Population_2000"));
          // Create StatisticsDescriptions
          StatisticsDescription pop1990StatisticsDescription = new StatisticsDescription(pop1990Field,
            new List<StatisticsFunction>()
              StatisticsFunction.Sum,
              StatisticsFunction.Average
          StatisticsDescription pop2000StatisticsDescription = new StatisticsDescription(pop2000Field,
          // Create TableStatisticsDescription
          TableStatisticsDescription tableStatisticsDescription = new TableStatisticsDescription(
            new List<StatisticsDescription>()
              pop1990StatisticsDescription, pop2000StatisticsDescription
          tableStatisticsDescription.GroupBy = new List<Field>() { regionField };
          tableStatisticsDescription.OrderBy = new List<SortDescription>() { new SortDescription(regionField) };
          // Calculate Statistics
          IReadOnlyList<TableStatisticsResult> tableStatisticsResults =
            countryFeatureClass.CalculateStatistics(tableStatisticsDescription);
          foreach (TableStatisticsResult tableStatisticsResult in tableStatisticsResults)
            // Get the Region name
            // If multiple fields had been passed into TableStatisticsDescription.GroupBy, there would be multiple values in TableStatisticsResult.GroupBy
            string regionName = tableStatisticsResult.GroupBy.First().Value.ToString();
            // Get the statistics results for the Population_1990 field
            StatisticsResult pop1990Statistics = tableStatisticsResult.StatisticsResults[0];
            double population1990Sum = pop1990Statistics.Sum;
            double population1990Average = pop1990Statistics.Average;
            // Get the statistics results for the Population_2000 field
            StatisticsResult pop2000Statistics = tableStatisticsResult.StatisticsResults[1];
            double population2000Sum = pop2000Statistics.Sum;
            double population2000Average = pop2000Statistics.Average;
            // Do something with the results here...
    Inheritance Hierarchy
    System.Object
       System.ValueType
          System.Enum
             ArcGIS.Core.Data.StatisticsFunction
    Requirements
