ArcGIS.Core.Data.Knowledge Namespace / KnowledgeGraphConnectionProperties Class / KnowledgeGraphConnectionProperties Constructor
A valid path to a file-based knowledge graph or service URL
Example
    Initializes a new instance of the KnowledgeGraphConnectionProperties class.
    Syntax
    Public Function New( _
       ByVal pathOrserviceURL As Uri _
    public KnowledgeGraphConnectionProperties(
       Uri pathOrserviceURL
    Parameters
    pathOrserviceURL
    Exceptions
    ExceptionDescription
    pathOrserviceURL is null.
    Example
    Opening a Connection to a KnowledgeGraph
      await QueuedTask.Run(() =>
        //Create a connection properties
        var kg_props =
            new KnowledgeGraphConnectionProperties(new Uri(url));
        try
          //Open a connection
          using (var kg = new KnowledgeGraph(kg_props))
            //TODO...use the KnowledgeGraph
        catch (GeodatabaseNotFoundOrOpenedException ex)
          System.Diagnostics.Debug.WriteLine(ex.ToString());
    Opening a Connection to a File KnowledgeGraph
        //Starting at 3.7, users can connect to a _file_ knowledge graph
        //The extension for a file kg is ".knowledgegraph"
        // Any path you want
        string kgPath = @"C:\Data\KG\Filebased_KG";
        string kgFileName = @"Test_File_KG.knowledgegraph";
        var kg_full_path = System.IO.Path.Combine(kgPath, kgFileName);
        var kg_props = new KnowledgeGraphConnectionProperties(new Uri(kg_full_path));
        try
          //Open a connection
            //TODO...use the File KnowledgeGraph
            var i = 0;
            //Get the featureclass definitions from the KG datastore
            var fc_defs = kg.GetDefinitions<FeatureClassDefinition>();
            //For each feature class definition, get the corresponding
            //feature class. Note: The name of the feature class will match
            //the name of its corresponding KnowledgeGraph named object type
            //in the KnowledgeGraph graph data model
            foreach (var fc_def in fc_defs)
              var fc_name = fc_def.GetName();
              System.Diagnostics.Debug.WriteLine($"FeatureClass[{i++}] {fc_name}");
    Retrieving GDB FeatureClasses and Definitions
        var kg_props =
        //Connect to the KnowledgeGraph datastore
        //KnowledgeGraph datastores contain tables and feature classes
            using (var fc = kg.OpenDataset<FeatureClass>(fc_name))
              //TODO - use the feature class
    Create a File Knowledge Graph with SchemaBuilder
      //Starting at 3.7, users can use _file_ knowledge graphs
      //The file knowledge graph must NOT already exist or a GeodatabaseWorkspaceException
      //exception will be thrown
      string finalFileName = string.Empty;
      // ensure new file name is unique
      string baseFileName = System.IO.Path.GetFileNameWithoutExtension(kgFileName);
      int extraCount = 0;
      string extraFileName = string.Empty;
      string fullPath = string.Empty;
      do
        fullPath = System.IO.Path.Combine(
                    kgPath, baseFileName + extraFileName + ".knowledgegraph");
        ++extraCount;
        extraFileName = $"({extraCount})";
      while (System.IO.File.Exists(fullPath));
      System.Diagnostics.Debug.WriteLine($"Creating {System.IO.Path.GetFileName(fullPath)}");
      var kgConnProps = new KnowledgeGraphConnectionProperties(
                                                      new Uri(fullPath));
      try
        using (var kg = SchemaBuilder.CreateFileKnowledgeGraph(kgConnProps))
          //TODO - use the new KG
      catch (Exception ex)
    Retrieving GDB Tables and Definitions
        var kg_props =
          //Get the table definitions from the KG datastore
          var tbl_defs = kg.GetDefinitions<TableDefinition>();
          //For each table definition, get the corresponding
          //table. Note: The name of the table will match the name
          //of its corresponding KnowledgeGraph named object type in
          //the KnowledgeGraph graph data model
          foreach (var tbl_def in tbl_defs)
            var tbl_name = tbl_def.GetName();
            using (var fc = kg.OpenDataset<Table>(tbl_name))
              //TODO - use the table
    Requirements
    ArcGIS Pro version: 3.2 or higher.
