ArcGIS.Core.Data.Knowledge Namespace / KnowledgeGraphDataModel Class
Members Example
    Represents the data model for the knowledge graph.
    Object Model
    KnowledgeGraphDataModel ClassKnowledgeGraphIdentifierInfo ClassKnowledgeGraphEntityType ClassSpatialReference Class
    Syntax
    Public NotInheritable Class KnowledgeGraphDataModel
       Inherits ArcGIS.Core.CoreObjectsBase
       Implements System.IDisposable
    public sealed class KnowledgeGraphDataModel : ArcGIS.Core.CoreObjectsBase, System.IDisposable
    Remarks
    The data model includes metadata about the knowledge graph, including but not limited to entity and relationship types, spatial reference, and information about generation of unique identifiers.
    Example
    Retrieving the Data Model
      await QueuedTask.Run(() =>
        //Create a connection properties
        var kg_props =
            new KnowledgeGraphConnectionProperties(new Uri(url));
        using (var kg = new KnowledgeGraph(kg_props))
          //Get the KnowledgeGraph Data Model
          using (var kg_dm = kg.GetDataModel())
            //TODO use KG data model...
    Get Data Model Properties
        var kg_props =
            var kg_name = System.IO.Path.GetFileName(
                     System.IO.Path.GetDirectoryName(kg_props.PathOrURL.ToString()));
            System.Diagnostics.Debug.WriteLine(
              $"\r\n'{kg_name}' Datamodel:\r\n-----------------");
            var time_stamp = kg_dm.GetTimestamp();
            var sr = kg_dm.GetSpatialReference();
            System.Diagnostics.Debug.WriteLine($"Timestamp: {time_stamp}");
            System.Diagnostics.Debug.WriteLine($"Sref: {sr.Wkid}");
              $"IsStrict: {kg_dm.GetIsStrict()}");
              $"OIDPropertyName: {kg_dm.GetOIDPropertyName()}");
              $"IsArcGISManaged: {kg_dm.GetIsArcGISManaged()}");
    Inheritance Hierarchy
    System.Object
          ArcGIS.Core.Data.Knowledge.KnowledgeGraphDataModel
    Requirements
    ArcGIS Pro version: 3.2 or higher.
