Public NotInheritable Class KnowledgeGraphEndPoint Inherits ArcGIS.Core.CoreObjectsBase Implements System.IDisposable
public sealed class KnowledgeGraphEndPoint : ArcGIS.Core.CoreObjectsBase, System.IDisposable
await QueuedTask.Run(() =>
//Create a connection properties
var kg_props =
new KnowledgeGraphConnectionProperties(new Uri(url));
using (var kg = new KnowledgeGraph(kg_props))
//Get the KnowledgeGraph Data Model
using (var kg_dm = kg.GetDataModel())
var dict_types = kg_dm.GetRelationshipTypes();
foreach (var kvp in dict_types)
var rel_type = kvp.Value;
var role = rel_type.GetRole();
//note "name" will be the same name as the corresponding
//feature class or table in the KG's relational gdb model
var name = rel_type.GetName();
//etc.
//Get relationship end points
var end_points = rel_type.GetEndPoints();
foreach (var end_point in end_points)
System.Diagnostics.Debug.WriteLine(
$"Origin: '{end_point.GetOriginEntityTypeName()}', " +
$"Destination: '{end_point.GetDestinationEntityTypeName()}'");
System.Object
ArcGIS.Core.Data.Knowledge.KnowledgeGraphEndPoint
