ArcGIS.Core.Data.Knowledge Namespace / KnowledgeGraphIdentifierGeneration Class
Members Example
    Represents an object containing information about how the knowledge graph service generates unique identifiers.
    Syntax
    Public NotInheritable Class KnowledgeGraphIdentifierGeneration
       Inherits ArcGIS.Core.CoreObjectsBase
       Implements System.IDisposable
    public sealed class KnowledgeGraphIdentifierGeneration : ArcGIS.Core.CoreObjectsBase, System.IDisposable
    Example
    Get Data Model Identifier Info
      await QueuedTask.Run(() =>
        //Create a connection properties
        var kg_props =
            new KnowledgeGraphConnectionProperties(new Uri(url));
        using (var kg = new KnowledgeGraph(kg_props))
          //Get the KnowledgeGraph Data Model
          using (var kg_dm = kg.GetDataModel())
            var kg_id_info = kg_dm.GetIdentifierInfo();
            var kg_id_gen = kg_id_info.GetIdentifierGeneration();
            if (kg_id_info is KnowledgeGraphNativeIdentifier kg_ni)
              System.Diagnostics.Debug.WriteLine(
                $"IdentifierInfo: KnowledgeGraphNativeIdentifier");
            else if (kg_id_info is KnowledgeGraphUniformIdentifier kg_ui)
                $"IdentifierInfo: KnowledgeGraphUniformIdentifier");
                $"IdentifierName: '{kg_ui.GetIdentifierName()}'");
              $"Identifier MethodHint: {kg_id_gen.GetMethodHint()}");
    Inheritance Hierarchy
    System.Object
          ArcGIS.Core.Data.Knowledge.KnowledgeGraphIdentifierGeneration
    Requirements
    ArcGIS Pro version: 3.2 or higher.
