ArcGIS.Core.Data.Knowledge Namespace / KnowledgeGraphNamedObjectType Class / GetAliasName Method
Example
    GetAliasName Method (KnowledgeGraphNamedObjectType)
    Gets the alias name for this named object type. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    Public Function GetAliasName() As String
    public string GetAliasName()
    Return Value
    Exceptions
    ExceptionDescription
    Example
    Get KnowledgeGraph Entity Types
      await QueuedTask.Run(() =>
        //Create a connection properties
        var kg_props =
            new KnowledgeGraphConnectionProperties(new Uri(url));
        using (var kg = new KnowledgeGraph(kg_props))
          //Get the KnowledgeGraph Data Model
          using (var kg_dm = kg.GetDataModel())
            var dict_types = kg_dm.GetEntityTypes();
            foreach (var kvp in dict_types)
              var entity_type = kvp.Value;
              var role = entity_type.GetRole();
              //note "name" will be the same name as the corresponding
              //feature class or table in the KG's relational gdb model
              var name = entity_type.GetName();
              var alias = entity_type.GetAliasName();
              var objectIDPropertyName = entity_type.GetObjectIDPropertyName();
              //etc
    Requirements
    ArcGIS Pro version: 3.2 or higher.
