ArcGIS.Core.Data.Knowledge Namespace / KnowledgeGraphNamedObjectType Class / GetIsStrict Method
    GetIsStrict Method (KnowledgeGraphNamedObjectType)
    Get a boolean indicating whether the named object type is strict in the data model. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    Public Function GetIsStrict() As Boolean
    public bool GetIsStrict()
    Return Value
    Exceptions
    ExceptionDescription
    Remarks
    If true, only admins and owners are able to edit the named object type.
    Requirements
    ArcGIS Pro version: 3.2 or higher.
