ArcGIS.Core.Geometry Namespace / IGeometryEngine Interface / SideBuffer Method / SideBuffer(IEnumerable<Polyline>,Double,LeftOrRightSide,LineCapType) Method
The polylines to buffer
The buffer distance
The side of the polyline to create the buffer
The line cap type
Example
    Constructs a buffer on one side of a polyline
    Syntax
    Parameters
    polylines
    distance
    The buffer distance
    side
    capType
    The line cap type
    Return Value
    List of geometries representing the side buffers
    Exceptions
    ExceptionDescription
    Geometries is null or empty
    The buffer distance must be a valid floating point number.
    The method is not implemented for LineCapType.Square.
    Remarks
    The spatial reference of the output geometries is the first not null or Unknown spatial reference found in the list of geometries. All other geometries are projected to this spatial reference, if necessary. If no such spatial reference is found, then the Unknown spatial reference is used if it is found in the list. Otherwise, the spatial reference is null.
    Example
    SideBuffer Many
      SpatialReference spatialReference = SpatialReferenceBuilder.CreateSpatialReference(102010);
      List<Coordinate2D> coordinates =
        new Coordinate2D(1200, 5800),
    new Coordinate2D(1400, 5800),
    new Coordinate2D(1400, 6000),
    new Coordinate2D(1300, 6000),
    new Coordinate2D(1300, 5700)
      Polyline polyline1 = PolylineBuilderEx.CreatePolyline(coordinates, spatialReference);
      coordinates.Clear();
      coordinates.Add(new Coordinate2D(1400, 6050));
      coordinates.Add(new Coordinate2D(1600, 6150));
      coordinates.Add(new Coordinate2D(1800, 6050));
      Polyline polyline2 = PolylineBuilderEx.CreatePolyline(coordinates, spatialReference);
      List<Polyline> polylines = [polyline1, polyline2];
      IReadOnlyList<Geometry> outGeometries = GeometryEngine.Instance.SideBuffer(polylines, 10, LeftOrRightSide.RightSide, LineCapType.Round);
    Requirements
