| Exception | Description |
| ArcGIS.Core.CalledOnWrongThreadException | This method or property must be called within the lambda passed to QueuedTask.Run. |
//Use GetDocumentEntityTypeName(KnowledgeGraphDataModel kg_dm) from //the 'Get Whether KG Has a Document Type' snippet to //get the documentNameType parameter bool GetEntityIsDocument(KnowledgeGraphEntityValue entity, string documentNameType = "") { if (string.IsNullOrEmpty(documentNameType)) return false; return entity.GetTypeName() == documentNameType; }
void ProcessGraphNamedObjectValue( KnowledgeGraphNamedObjectValue kg_named_obj_val) { if (kg_named_obj_val is KnowledgeGraphEntityValue kg_entity) { var label = kg_entity.GetLabel(); //TODO - use label } else if (kg_named_obj_val is KnowledgeGraphRelationshipValue kg_rel) { var has_entity_ids = kg_rel.GetHasRelatedEntityIDs(); if (kg_rel.GetHasRelatedEntityIDs()) { var origin_id = kg_rel.GetOriginID(); var dest_id = kg_rel.GetDestinationID(); //TODO - use ids } } var id = kg_named_obj_val.GetID(); var oid = kg_named_obj_val.GetObjectID(); //Note: Typename corresponds to the name of the feature class or table //in the relational gdb model -and- to the name of the KnowledgeGraphNamedObjectType //in the knowledge graph data model var type_name = kg_named_obj_val.GetTypeName(); //TODO use id, object id, etc. } //Object values include entities, relationships, and anonymous objects void ProcessGraphObjectValue(KnowledgeGraphObjectValue kg_obj_val) { switch (kg_obj_val) { case KnowledgeGraphEntityValue kg_entity: ProcessGraphNamedObjectValue(kg_entity); break; case KnowledgeGraphRelationshipValue kg_rel: ProcessGraphNamedObjectValue(kg_rel); break; default: //Anonymous objects break; } //graph object values have a set of properties (equivalent //to a collection of key/value pairs) var keys = kg_obj_val.GetKeys(); foreach (var key in keys) ProcessKnowledgeGraphRowValue(kg_obj_val[key]);//Recurse } //Process a KnowledgeGraphValue from a query or search void ProcessGraphValue(KnowledgeGraphValue kg_val) { switch (kg_val) { case KnowledgeGraphPrimitiveValue kg_prim: //KnowledgeGraphPrimitiveValue not currently used in //query and search ProcessKnowledgeGraphRowValue(kg_prim.GetValue());//Recurse return; case KnowledgeGraphArrayValue kg_array: var count = kg_array.GetSize(); //Recursively process each value in the array for (ulong i = 0; i < count; i++) ProcessKnowledgeGraphRowValue(kg_array[i]);//Recurse return; case KnowledgeGraphPathValue kg_path: //Entities var entity_count = kg_path.GetEntityCount(); //Recursively process each entity value in the path for (ulong i = 0; i < entity_count; i++) ProcessGraphObjectValue(kg_path.GetEntity(i));//Recurse //Recursively process each relationship value in the path var relate_count = kg_path.GetRelationshipCount(); for (ulong i = 0; i < relate_count; i++) ProcessGraphObjectValue(kg_path.GetRelationship(i));//Recurse return; case KnowledgeGraphObjectValue kg_object: ProcessGraphObjectValue(kg_object);//Recurse return; default: var type_string = kg_val.GetType().ToString(); System.Diagnostics.Debug.WriteLine( $"Unknown: '{type_string}'"); return; } } //Process each value from the KnowledgeGraphRow array void ProcessKnowledgeGraphRowValue(object value) { switch (value) { //Graph value? case KnowledgeGraphValue kg_val: var kg_type = kg_val.KnowledgeGraphValueType.ToString(); System.Diagnostics.Debug.WriteLine( $"KnowledgeGraphValue: '{kg_type}'"); ProcessGraphValue(kg_val);//Recurse return; //Primitive types...add additional logic as needed case System.DBNull dbn: System.Diagnostics.Debug.WriteLine("DBNull.Value"); return; case string str: System.Diagnostics.Debug.WriteLine($"'{str}' (string)"); return; case long l_val: System.Diagnostics.Debug.WriteLine($"{l_val} (long)"); return; case int i_val: System.Diagnostics.Debug.WriteLine($"{i_val} (int)"); return; case short s_val: System.Diagnostics.Debug.WriteLine($"{s_val} (short)"); return; case double d_val: System.Diagnostics.Debug.WriteLine($"{d_val} (double)"); return; case float f_val: System.Diagnostics.Debug.WriteLine($"{f_val} (float)"); return; case DateTime dt_val: System.Diagnostics.Debug.WriteLine($"{dt_val} (DateTime)"); return; case DateOnly dt_only_val: System.Diagnostics.Debug.WriteLine($"{dt_only_val} (DateOnly)"); return; case TimeOnly tm_only_val: System.Diagnostics.Debug.WriteLine($"{tm_only_val} (TimeOnly)"); return; case DateTimeOffset dt_tm_offset_val: System.Diagnostics.Debug.WriteLine( $"{dt_tm_offset_val} (DateTimeOffset)"); return; case System.Guid guid_val: var guid_string = guid_val.ToString("B"); System.Diagnostics.Debug.WriteLine($"'{guid_string}' (Guid)"); return; case ArcGIS.Core.Geometry.Geometry geom_val: var geom_type = geom_val.GeometryType.ToString(); var is_empty = geom_val.IsEmpty; var wkid = geom_val.SpatialReference?.Wkid ?? 0; System.Diagnostics.Debug.WriteLine( $"geometry: {geom_type}, empty: {is_empty}, sr_wkid {wkid} (shape)"); return; default: //Blob? Others? var type_str = value.GetType().ToString(); System.Diagnostics.Debug.WriteLine($"Primitive: {type_str}"); return; } } // ...submit query or search //using (var kgRowCursor = kg.SubmitQuery(kg_qf)) { //using (var kgRowCursor = kg.SubmitSearch(kg_sf)) { // ...wait for rows ... // while (await kgRowCursor.WaitForRowsAsync()) { // ...rows have been retrieved // while (kgRowCursor.MoveNext()) { // ...get the current KnowledgeGraphRow // using (var graph_row = kgRowCursor.Current) { // var val_count = (int)graph_row.GetCount(); // for (int i = 0; i<val_count; i++) // ProcessKnowledgeGraphRowValue(graph_row[i]);
