ArcGIS.Core.Data.Knowledge Namespace / KnowledgeGraphObjectValue Class / GetKeys Method
Example
    GetKeys Method (KnowledgeGraphObjectValue)
    Gets the set of keys associated with the graph object value. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    public virtual IReadOnlyList<string> GetKeys()
    Public Overridable Function GetKeys() As IReadOnlyList(Of String)
    Return Value
    Exceptions
    ExceptionDescription
    Example
    Submit a Text Search
      await QueuedTask.Run(async () =>
        //and assuming you have established a connection to a knowledge graph
        //Construct a KG search filter. Search text uses Apache Lucene Query Parser
        //syntax - https://lucene.apache.org/core/2_9_4/queryparsersyntax.html
        var kg_sf = new KnowledgeGraphSearchFilter()
          SearchTarget = KnowledgeGraphNamedTypeCategory.Entity,
          SearchText = "Acme Electric Co.",
          ReturnSearchContext = true,
          MaxRowCount = 10 //Default is 100 if not specified
        //submit the search - returns a KnowledgeGraphCursor
        var e = 0;
        using (var kg_rc = kg.SubmitSearch(kg_sf))
          //wait for rows to be returned from the server
          //note the "await"...
          while (await kg_rc.WaitForRowsAsync())
            //Rows have been retrieved - process this "batch"...
            while (kg_rc.MoveNext())
              //Get the current KnowledgeGraphRow
              using (var graph_row = kg_rc.Current)
                //We are returning entities from this search
                var entity = graph_row[0] as KnowledgeGraphEntityValue;
                var entity_type = entity.GetTypeName();
                var record = new List<string>();
                //discover keys(aka "fields") dynamically via GetKeys
                foreach (var prop_name in entity.GetKeys())
                  var obj_val = entity[prop_name] ?? "null";
                  record.Add(obj_val.ToString());
                System.Diagnostics.Debug.WriteLine(
                  $"{entity_type}[{e++}] " + string.Join(", ", record));
                //or use "Process a KnowledgeGraphRow Value" snippet
                //ProcessKnowledgeGraphRowValue(entity);
          }//WaitForRowsAsync
        }//SubmitSearch
    Requirements
    ArcGIS Pro version: 3.2 or higher.
