ArcGIS.Desktop.Core Namespace / Item Class / SaveMetadataAsUsingCustomXSLT Method
Example
    SaveMetadataAsUsingCustomXSLT Method (Item)
    Save the metadata of the current item using customized XSLT. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    Public Sub SaveMetadataAsUsingCustomXSLT( _
       ByVal customXSLTFilePath As String, _
       ByVal outputFilePath As String _
    public void SaveMetadataAsUsingCustomXSLT(
       string customXSLTFilePath,
       string outputFilePath
    Parameters
    customXSLTFilePath
    outputFilePath
    Exceptions
    ExceptionDescription
    Example
    Item: Save the metadata of the current item using customized XSLT: SaveMetadataAsUsingCustomXSLT
      // Note: Needs QueuedTask to run
      metadataItemToSaveAsUsingCustomXSLT.SaveMetadataAsUsingCustomXSLT(@"E:\Data\Metadata\CustomXSLT.xsl", @"E:\Temp\OutputXMLCustom.xml");
    Requirements
