ArcGIS.Desktop.Core Namespace / Item Class / SaveMetadataAsXML Method
Example
    SaveMetadataAsXML Method (Item)
    Save the metadata of the current item as XML. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    Public Sub SaveMetadataAsXML( _
       ByVal outputFilePath As String, _
       ByVal outputType As MDSaveAsXMLOption _
    public void SaveMetadataAsXML(
       string outputFilePath,
       MDSaveAsXMLOption outputType
    Parameters
    outputFilePath
    outputType
    Exceptions
    ExceptionDescription
    Example
    Item: Save the metadata of the current item as XML: SaveMetadataAsXML
      metadataItemToSaveAsXML.SaveMetadataAsXML(@"E:\Temp\OutputXML.xml", MDSaveAsXMLOption.esriExactCopy);
    Requirements
