ArcGIS.Desktop.Core Namespace / Item Class / UpgradeMetadata Method
Example
    UpgradeMetadata Method (Item)
    Upgrade the metadata of the current item. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    Public Sub UpgradeMetadata( _
       ByVal upgradeOption As MDUpgradeOption _
    public void UpgradeMetadata(
       MDUpgradeOption upgradeOption
    Parameters
    upgradeOption
    Exceptions
    ExceptionDescription
    Example
    Item: Upgrade the metadata of the current item: UpgradeMetadata
      var fgdcItem = ItemFactory.Instance.Create(@"C:\projectAlpha\GDBs\testData.gdb");
      // Note: Needs QueuedTask to run
      fgdcItem.UpgradeMetadata(MDUpgradeOption.esriUpgradeFgdcCsdgm);
    Requirements
