ArcGIS.Core.Data.Knowledge Namespace / KnowledgeGraphRelationshipValue Class
Members Example
    Represents a knowledge graph relationship.
    Syntax
    Public Class KnowledgeGraphRelationshipValue
       Inherits KnowledgeGraphNamedObjectValue
       Implements System.IDisposable
    public class KnowledgeGraphRelationshipValue : KnowledgeGraphNamedObjectValue, System.IDisposable
    Example
    Process a KnowledgeGraphRow Value
    void ProcessGraphNamedObjectValue(
      KnowledgeGraphNamedObjectValue kg_named_obj_val)
      if (kg_named_obj_val is KnowledgeGraphEntityValue kg_entity)
        var label = kg_entity.GetLabel();
        //TODO - use label
      else if (kg_named_obj_val is KnowledgeGraphRelationshipValue kg_rel)
        var has_entity_ids = kg_rel.GetHasRelatedEntityIDs();
        if (kg_rel.GetHasRelatedEntityIDs())
          var origin_id = kg_rel.GetOriginID();
          var dest_id = kg_rel.GetDestinationID();
          //TODO - use ids
      var id = kg_named_obj_val.GetID();
      var oid = kg_named_obj_val.GetObjectID();
      //Note: Typename corresponds to the name of the feature class or table
      //in the relational gdb model -and- to the name of the KnowledgeGraphNamedObjectType
      //in the knowledge graph data model
      var type_name = kg_named_obj_val.GetTypeName();
      //TODO use id, object id, etc.
    //Object values include entities, relationships, and anonymous objects
    void ProcessGraphObjectValue(KnowledgeGraphObjectValue kg_obj_val)
      switch (kg_obj_val)
        case KnowledgeGraphEntityValue kg_entity:
          ProcessGraphNamedObjectValue(kg_entity);
          break;
        case KnowledgeGraphRelationshipValue kg_rel:
          ProcessGraphNamedObjectValue(kg_rel);
          break;
        default:
          //Anonymous objects
          break;
      //graph object values have a set of properties (equivalent
      //to a collection of key/value pairs)
      var keys = kg_obj_val.GetKeys();
      foreach (var key in keys)
        ProcessKnowledgeGraphRowValue(kg_obj_val[key]);//Recurse
    //Process a KnowledgeGraphValue from a query or search
    void ProcessGraphValue(KnowledgeGraphValue kg_val)
      switch (kg_val)
        case KnowledgeGraphPrimitiveValue kg_prim:
          //KnowledgeGraphPrimitiveValue not currently used in
          //query and search
          ProcessKnowledgeGraphRowValue(kg_prim.GetValue());//Recurse
          return;
        case KnowledgeGraphArrayValue kg_array:
          var count = kg_array.GetSize();
          //Recursively process each value in the array
          for (ulong i = 0; i < count; i++)
            ProcessKnowledgeGraphRowValue(kg_array[i]);//Recurse
          return;
        case KnowledgeGraphPathValue kg_path:
          //Entities
          var entity_count = kg_path.GetEntityCount();
          //Recursively process each entity value in the path
          for (ulong i = 0; i < entity_count; i++)
            ProcessGraphObjectValue(kg_path.GetEntity(i));//Recurse
          //Recursively process each relationship value in the path
          var relate_count = kg_path.GetRelationshipCount();
          for (ulong i = 0; i < relate_count; i++)
            ProcessGraphObjectValue(kg_path.GetRelationship(i));//Recurse
          return;
        case KnowledgeGraphObjectValue kg_object:
          ProcessGraphObjectValue(kg_object);//Recurse
          return;
        default:
          var type_string = kg_val.GetType().ToString();
          System.Diagnostics.Debug.WriteLine(
            $"Unknown: '{type_string}'");
          return;
    //Process each value from the KnowledgeGraphRow array
    void ProcessKnowledgeGraphRowValue(object value)
      switch (value)
        //Graph value?
        case KnowledgeGraphValue kg_val:
          var kg_type = kg_val.KnowledgeGraphValueType.ToString();
            $"KnowledgeGraphValue: '{kg_type}'");
          ProcessGraphValue(kg_val);//Recurse
          return;
        //Primitive types...add additional logic as needed
        case System.DBNull dbn:
          System.Diagnostics.Debug.WriteLine("DBNull.Value");
          return;
        case string str:
          System.Diagnostics.Debug.WriteLine($"'{str}' (string)");
          return;
        case long l_val:
          System.Diagnostics.Debug.WriteLine($"{l_val} (long)");
          return;
        case int i_val:
          System.Diagnostics.Debug.WriteLine($"{i_val} (int)");
          return;
        case short s_val:
          System.Diagnostics.Debug.WriteLine($"{s_val} (short)");
          return;
        case double d_val:
          System.Diagnostics.Debug.WriteLine($"{d_val} (double)");
          return;
        case float f_val:
          System.Diagnostics.Debug.WriteLine($"{f_val} (float)");
          return;
        case DateTime dt_val:
          System.Diagnostics.Debug.WriteLine($"{dt_val} (DateTime)");
          return;
        case DateOnly dt_only_val:
          System.Diagnostics.Debug.WriteLine($"{dt_only_val} (DateOnly)");
          return;
        case TimeOnly tm_only_val:
          System.Diagnostics.Debug.WriteLine($"{tm_only_val} (TimeOnly)");
          return;
        case DateTimeOffset dt_tm_offset_val:
            $"{dt_tm_offset_val} (DateTimeOffset)");
          return;
        case System.Guid guid_val:
          var guid_string = guid_val.ToString("B");
          System.Diagnostics.Debug.WriteLine($"'{guid_string}' (Guid)");
          return;
        case ArcGIS.Core.Geometry.Geometry geom_val:
          var geom_type = geom_val.GeometryType.ToString();
          var is_empty = geom_val.IsEmpty;
          var wkid = geom_val.SpatialReference?.Wkid ?? 0;
            $"geometry: {geom_type}, empty: {is_empty}, sr_wkid {wkid} (shape)");
          return;
        default:
          //Blob? Others?
          var type_str = value.GetType().ToString();
          System.Diagnostics.Debug.WriteLine($"Primitive: {type_str}");
          return;
    // ...submit query or search
    //using (var kgRowCursor = kg.SubmitQuery(kg_qf)) {
    //using (var kgRowCursor = kg.SubmitSearch(kg_sf)) {
    //  ...wait for rows ...
    //  while (await kgRowCursor.WaitForRowsAsync()) {
    //   ...rows have been retrieved
    //   while (kgRowCursor.MoveNext()) {
    //     ...get the current KnowledgeGraphRow
    //     using (var graph_row = kgRowCursor.Current) {
    //        var val_count = (int)graph_row.GetCount();
    //        for (int i = 0; i<val_count; i++)
    //           ProcessKnowledgeGraphRowValue(graph_row[i]);
    Create a new Relationship from Existing Entities 1
      var create_rel = await QueuedTask.Run(() =>
        //Instantiate an operation for the Create
        var edit_op = new EditOperation()
          Name = "Create a new relationship record",
          SelectNewFeatures = true
        //Use datasets or feature layer(s) or standalone table(s)
        //Get a reference to the KnowledgeGraph
        //var kg = ... ;
        //We will use a relate called 'HasEmployee' to relate an Organization w/ a Person
        //Use either tables or map members to get the rows to be related...
        var org_fc = kg.OpenDataset<FeatureClass>("Organization");
        var person_tbl = kg.OpenDataset<Table>("Person");
        //Get the relationship dataset
        //We can use either a table or standalone table
        var emp_tbl = kg.OpenDataset<Table>("HasEmployee");
        //we need the names of the origin and destination relationship properties
        var kg_prop_info = kg.GetPropertyNameInfo();
        //Arbitrarily use the first record from the two entity datasets "to be" related
        //Entities are always related by Global ID. Origin to Destination specifies the
        //direction (of the relate).
        //Populate the attributes for the relationship
        var attribs = new Dictionary<string, object>();
        using (var rc = org_fc.Search())
          if (rc.MoveNext())
            //Use the KnowledgeGraphPropertyInfo to avoid hardcoding...
            attribs[kg_prop_info.OriginIDPropertyName] = rc.Current.GetGlobalID();
        using (var rc = person_tbl.Search())
          if (rc.MoveNext())
            attribs[kg_prop_info.DestinationIDPropertyName] = rc.Current.GetGlobalID();
        //Add any extra attribute information for the relation as needed
        attribs["StartDate"] = new DateTimeOffset(DateTime.Now);
        //Add a create for the relationship to the operation
        edit_op.Create(emp_tbl, attribs);
        //Do the create
        return edit_op.Execute();
    Inheritance Hierarchy
    System.Object
       ArcGIS.Core.CoreObjectsBase
          ArcGIS.Core.Data.Knowledge.KnowledgeGraphValue
             ArcGIS.Core.Data.Knowledge.KnowledgeGraphObjectValue
                ArcGIS.Core.Data.Knowledge.KnowledgeGraphNamedObjectValue
                   ArcGIS.Core.Data.Knowledge.KnowledgeGraphRelationshipValue
    Requirements
    ArcGIS Pro version: 3.2 or higher.
