ArcGIS.Desktop.Editing Namespace / ParallelOffset Class / CopyToSeparateFeatures Property
    CopyToSeparateFeatures Property (ParallelOffset)
    Gets if connected lines should be copied to separate lines. (Default value = false).
    Syntax
    public bool CopyToSeparateFeatures {get;}
    Public ReadOnly Property CopyToSeparateFeatures As Boolean
    Remarks
    This setting is only used if AlignConnected is true. When set to true, this setting creates a separate line for each connected line in the selection, otherwise a single line is created.
    Requirements
