ArcGIS.Desktop.Editing Namespace / ParallelOffset Class / Iterations Property
    Iterations Property (ParallelOffset)
    Gets the number of parallel offset copies to create. (Default value = 1)
    Syntax
    public int Iterations {get;}
    Public ReadOnly Property Iterations As Integer
    Remarks
    The copies are created sequentially by the offset distance. For example, copying a line to one side specifying a distance of 5 and 2 iterations will create one line at 5 and one at 10 from the original line, not two lines at 5.
    Requirements
