ArcGIS.Desktop.Editing Namespace / ParallelOffset.Builder Class / Distance Property
Example
    Distance Property (ParallelOffset.Builder)
    Gets and sets the offset distance in map units. (Default value = 0)
    Syntax
    public double Distance {get; set;}
    Public Property Distance As Double
    Example
    Edit Operation ParallelOffset
    // Creates parallel offset features from the selected features.
    var parallelOffsetMapView = MapView.Active;
    if (parallelOffsetMapView == null)
      return;
    await QueuedTask.Run(() =>
        //Create parallel features from the selected features
        //find the roads layer
        var roadsLayer = parallelOffsetMapView.Map.FindLayers("Roads")?[0];
        //instantiate parallelOffset builder and set parameters
        var parOffsetBuilder = new ParallelOffset.Builder()
          Selection = parallelOffsetMapView.Map.GetSelection(),
          Template = roadsLayer.GetTemplate("Freeway"),
          Distance = 200,
          Side = ParallelOffset.SideType.Both,
          Corner = ParallelOffset.CornerType.Mitered,
          Iterations = 1,
          AlignConnected = false,
          CopyToSeparateFeatures = false,
          RemoveSelfIntersectingLoops = true
        //create EditOperation and execute
        var parallelOp = new EditOperation();
        parallelOp.Create(parOffsetBuilder);
        if (!parallelOp.IsEmpty)
          var result = parallelOp.Execute(); //Execute and ExecuteAsync will return true if the operation was successful and false if not
    Requirements
