public ParallelOffset.SideType Side {get; set;}
Public Property Side As ParallelOffset.SideType
// Creates parallel offset features from the selected features. var parallelOffsetMapView = MapView.Active; if (parallelOffsetMapView == null) return; await QueuedTask.Run(() => { //Create parallel features from the selected features //find the roads layer var roadsLayer = parallelOffsetMapView.Map.FindLayers("Roads")?[0]; //instantiate parallelOffset builder and set parameters var parOffsetBuilder = new ParallelOffset.Builder() { Selection = parallelOffsetMapView.Map.GetSelection(), Template = roadsLayer.GetTemplate("Freeway"), Distance = 200, Side = ParallelOffset.SideType.Both, Corner = ParallelOffset.CornerType.Mitered, Iterations = 1, AlignConnected = false, CopyToSeparateFeatures = false, RemoveSelfIntersectingLoops = true }; //create EditOperation and execute var parallelOp = new EditOperation(); parallelOp.Create(parOffsetBuilder); if (!parallelOp.IsEmpty) { var result = parallelOp.Execute(); //Execute and ExecuteAsync will return true if the operation was successful and false if not } });
