// Splits the specified feature at the given points. await QueuedTask.Run(() => { //Split features at given points //Split features using EditOperation.Split overloads var splitFeatures = new EditOperation() { Name = "Split Features" }; //Split the feature at given points splitFeatures.Split(featureLayer, objectId, splitPoints); //Execute to execute the operation //Must be called within QueuedTask.Run if (!splitFeatures.IsEmpty) { //Execute and ExecuteAsync will return true if the operation was successful and false if not var result = splitFeatures.Execute(); //or use async flavor //await splitAtPointsFeatures.ExecuteAsync(); } }); // Splits a feature in the specified feature layer based on a given percentage and object ID. await QueuedTask.Run(() => { var percentage = 25.0; //Split features using EditOperation.Split overloads var splitFeatures = new EditOperation() { Name = "Split Features" }; // split using percentage var splitByPercentage = new SplitByPercentage() { Percentage = percentage, SplitFromStartPoint = true }; splitFeatures.Split(featureLayer, objectId, splitByPercentage); //Execute to execute the operation //Must be called within QueuedTask.Run if (!splitFeatures.IsEmpty) { //Execute and ExecuteAsync will return true if the operation was successful and false if not var result = splitFeatures.Execute(); //or use async flavor //await splitAtPointsFeatures.ExecuteAsync(); } }); // Splits a feature in the specified feature layer into the specified number of parts. await QueuedTask.Run(() => { var numParts = 3; // split using equal parts //Split features using EditOperation.Split overloads var splitFeatures = new EditOperation() { Name = "Split Features" }; var splitByEqualParts = new SplitByEqualParts() { NumParts = numParts }; splitFeatures.Split(featureLayer, objectId, splitByEqualParts); //Execute to execute the operation //Must be called within QueuedTask.Run if (!splitFeatures.IsEmpty) { //Execute and ExecuteAsync will return true if the operation was successful and false if not var result = splitFeatures.Execute(); //or use async flavor //await splitAtPointsFeatures.ExecuteAsync(); } }); // Splits a feature in the specified feature layer at a given distance and object ID. await QueuedTask.Run(() => { var distance = 150.0; //Split features using EditOperation.Split overloads var splitFeatures = new EditOperation() { Name = "Split Features" }; // split using single distance var splitByDistance = new SplitByDistance() { Distance = distance, SplitFromStartPoint = false }; splitFeatures.Split(featureLayer, objectId, splitByDistance); //Execute to execute the operation //Must be called within QueuedTask.Run if (!splitFeatures.IsEmpty) { //Execute and ExecuteAsync will return true if the operation was successful and false if not var result = splitFeatures.Execute(); //or use async flavor //await splitAtPointsFeatures.ExecuteAsync(); } }); // Splits a feature in the specified feature layer at a given distance and object ID. await QueuedTask.Run(() => { var distances = new List<double> { 100.0, 200.0, 50.0 }; //Split features using EditOperation.Split overloads var splitFeatures = new EditOperation() { Name = "Split Features" }; // split using varying distance var splitByVaryingDistance = new SplitByVaryingDistance() { Distances = distances, SplitFromStartPoint = true, ProportionRemainder = true }; splitFeatures.Split(featureLayer, objectId, splitByVaryingDistance); //Execute to execute the operation //Must be called within QueuedTask.Run if (!splitFeatures.IsEmpty) { //Execute and ExecuteAsync will return true if the operation was successful and false if not var result = splitFeatures.Execute(); //or use async flavor //await splitAtPointsFeatures.ExecuteAsync(); } });
