ArcGIS.Desktop.Editing Namespace / SplitByPercentage Class / SplitByPercentage Constructor
Example
    Create a new Split by Percentage object.
    Syntax
    Public Function New()
    public SplitByPercentage()
    Example
    Edit Operation Split Features
    // Splits the specified feature at the given points.
    await QueuedTask.Run(() =>
        //Split features at given points
        //Split features using EditOperation.Split overloads
        var splitFeatures = new EditOperation() { Name = "Split Features" };
        //Split the feature at given points
        splitFeatures.Split(featureLayer, objectId, splitPoints);
        //Execute to execute the operation
        //Must be called within QueuedTask.Run
        if (!splitFeatures.IsEmpty)
          //Execute and ExecuteAsync will return true if the operation was successful and false if not
          var result = splitFeatures.Execute();
          //or use async flavor
          //await splitAtPointsFeatures.ExecuteAsync();
    // Splits a feature in the specified feature layer based on a given percentage and object ID.
      var percentage = 25.0;
      // split using percentage
      var splitByPercentage = new SplitByPercentage() { Percentage = percentage, SplitFromStartPoint = true };
      splitFeatures.Split(featureLayer, objectId, splitByPercentage);
    // Splits a feature in the specified feature layer into the specified number of parts.
        var numParts = 3;
        // split using equal parts
        var splitByEqualParts = new SplitByEqualParts() { NumParts = numParts };
        splitFeatures.Split(featureLayer, objectId, splitByEqualParts);
    // Splits a feature in the specified feature layer at a given distance and object ID.
        var distance = 150.0;
        // split using single distance
        var splitByDistance = new SplitByDistance() { Distance = distance, SplitFromStartPoint = false };
        splitFeatures.Split(featureLayer, objectId, splitByDistance);
       var distances = new List<double> { 100.0, 200.0, 50.0 };
       // split using varying distance
       var splitByVaryingDistance = new SplitByVaryingDistance() { Distances = distances, SplitFromStartPoint = true, ProportionRemainder = true };
       splitFeatures.Split(featureLayer, objectId, splitByVaryingDistance);
    Requirements
