ArcGIS.Core.Data.Knowledge Namespace / KnowledgeGraphSearchFilter Class / ReturnSearchContext Property
Example
    Gets or sets whether to include search context fields. The default value is false.
    Syntax
    Public Property ReturnSearchContext As Boolean
    public bool ReturnSearchContext {get; set;}
    Remarks
    Search context fields include propertyNames, scores and highlights. If ReturnSearchContext is set true, then the cypher_clause is ignored and exactly the tuple { id(doc), [propertyName1, ..., propertyNameN], [score1,..., scoreN], [highlight1, ..., highlightN]} is returned in the result set for each document. The default value is false.
    Example
    Submit a Text Search
      await QueuedTask.Run(async () =>
        //and assuming you have established a connection to a knowledge graph
        //Construct a KG search filter. Search text uses Apache Lucene Query Parser
        //syntax - https://lucene.apache.org/core/2_9_4/queryparsersyntax.html
        var kg_sf = new KnowledgeGraphSearchFilter()
          SearchTarget = KnowledgeGraphNamedTypeCategory.Entity,
          SearchText = "Acme Electric Co.",
          ReturnSearchContext = true,
          MaxRowCount = 10 //Default is 100 if not specified
        //submit the search - returns a KnowledgeGraphCursor
        var e = 0;
        using (var kg_rc = kg.SubmitSearch(kg_sf))
          //wait for rows to be returned from the server
          //note the "await"...
          while (await kg_rc.WaitForRowsAsync())
            //Rows have been retrieved - process this "batch"...
            while (kg_rc.MoveNext())
              //Get the current KnowledgeGraphRow
              using (var graph_row = kg_rc.Current)
                //We are returning entities from this search
                var entity = graph_row[0] as KnowledgeGraphEntityValue;
                var entity_type = entity.GetTypeName();
                var record = new List<string>();
                //discover keys(aka "fields") dynamically via GetKeys
                foreach (var prop_name in entity.GetKeys())
                  var obj_val = entity[prop_name] ?? "null";
                  record.Add(obj_val.ToString());
                System.Diagnostics.Debug.WriteLine(
                  $"{entity_type}[{e++}] " + string.Join(", ", record));
                //or use "Process a KnowledgeGraphRow Value" snippet
                //ProcessKnowledgeGraphRowValue(entity);
          }//WaitForRowsAsync
        }//SubmitSearch
    Requirements
    ArcGIS Pro version: 3.2 or higher.
