await QueuedTask.Run(async () =>
//and assuming you have established a connection to a knowledge graph
//Construct a KG search filter. Search text uses Apache Lucene Query Parser
//syntax - https://lucene.apache.org/core/2_9_4/queryparsersyntax.html
var kg_sf = new KnowledgeGraphSearchFilter()
SearchTarget = KnowledgeGraphNamedTypeCategory.Entity,
SearchText = "Acme Electric Co.",
ReturnSearchContext = true,
MaxRowCount = 10 //Default is 100 if not specified
//submit the search - returns a KnowledgeGraphCursor
var e = 0;
using (var kg_rc = kg.SubmitSearch(kg_sf))
//wait for rows to be returned from the server
//note the "await"...
while (await kg_rc.WaitForRowsAsync())
//Rows have been retrieved - process this "batch"...
while (kg_rc.MoveNext())
//Get the current KnowledgeGraphRow
using (var graph_row = kg_rc.Current)
//We are returning entities from this search
var entity = graph_row[0] as KnowledgeGraphEntityValue;
var entity_type = entity.GetTypeName();
var record = new List<string>();
//discover keys(aka "fields") dynamically via GetKeys
foreach (var prop_name in entity.GetKeys())
var obj_val = entity[prop_name] ?? "null";
record.Add(obj_val.ToString());
System.Diagnostics.Debug.WriteLine(
$"{entity_type}[{e++}] " + string.Join(", ", record));
//or use "Process a KnowledgeGraphRow Value" snippet
//ProcessKnowledgeGraphRowValue(entity);
}//WaitForRowsAsync
}//SubmitSearch
