await QueuedTask.Run(async () =>
//and assuming you have established a connection to a knowledge graph
//Construct an openCypher query - return the first 10 entities (whatever
//they are...)
var query = "MATCH (n) RETURN n LIMIT 10";//default limit is 100 if not specified
//other examples...
//query = "MATCH (a:Person) RETURN [a.name, a.age] ORDER BY a.age DESC LIMIT 50";
//query = "MATCH (b:Person) RETURN { Xperson: { Xname: b.name, Xage: b.age } } ORDER BY b.name DESC";
//query = "MATCH p = (c:Person)-[:HasCar]-() RETURN p ORDER BY c.name DESC";
//Create a query filter
//Note: OutputSpatialReference is currently ignored
var kg_qf = new KnowledgeGraphQueryFilter()
QueryText = query
//Optionally - u can choose to include provenance in the results
//(_if_ the KG has provenance - otherwise the query will fail)
bool includeProvenanceIfPresent = KnowledgeGraphSupportsProvenance(kg);
if (includeProvenanceIfPresent)
//Only include if the KG has provenance
kg_qf.ProvenanceBehavior =
KnowledgeGraphProvenanceBehavior.Include;//default is exclude
//submit the query - returns a KnowledgeGraphCursor
using (var kg_rc = kg.SubmitQuery(kg_qf))
//wait for rows to be returned from the server
//note the "await"...
while (await kg_rc.WaitForRowsAsync())
//Rows have been retrieved - process this "batch"...
while (kg_rc.MoveNext())
//Get the current KnowledgeGraphRow
using (var graph_row = kg_rc.Current)
//Graph row is an array, process all returned values...
var val_count = (int)graph_row.GetCount();
for (int i = 0; i < val_count; i++)
var retval = graph_row[i];
//Process row value (note: recursive)
//See "Process a KnowledgeGraphRow Value" snippet
ProcessKnowledgeGraphRowValue(retval);
}//WaitForRowsAsync
}//SubmitQuery
