Public Function New( _ ByVal lasDS As LasDataset _ )
public LasDatasetLayerCreationParams( LasDataset lasDS )
Parameters
- lasDS
- A ArcGIS.Core.Data.Analyst3D.LasDataset object.
if (lasDataset == null)
throw new ArgumentNullException(nameof(lasDataset));
var lasCP_ds = new LasDatasetLayerCreationParams(lasDataset);
lasCP_ds.Name = "My LAS Layer";
lasCP_ds.IsVisible = false;
// Note: Needs QueuedTask to run
//Create the layer to the LAS dataset
var lasDatasetLayer_ds = LayerFactory.Instance.CreateLayer<LasDatasetLayer>(lasCP_ds, map);
var lasCP_renderers = new LasDatasetLayerCreationParams(lasDataset);
lasCP_renderers.Name = "My LAS Layer";
lasCP_renderers.IsVisible = false;
// create a point elevation renderer
var ptR = new LasStretchRendererDefinition();
// accept all defaults
// create a simple edge renderer
var edgeR = new TinEdgeRendererDefintion();
// add renderers to dictionary
var l_dict = new Dictionary<SurfaceRendererTarget, TinRendererDefinition>();
l_dict.Add(SurfaceRendererTarget.Points, ptR);
l_dict.Add(SurfaceRendererTarget.Edges, edgeR);
// assign dictionary to creation params
lasCP_renderers.RendererDefinitions = l_dict;
var lasDatasetLayer_rd = LayerFactory.Instance.CreateLayer<LasDatasetLayer>(lasCP_renderers, map);
