ArcGIS.Desktop.Mapping Namespace / TerrainLayerCreationParams Class / TerrainLayerCreationParams Constructor / TerrainLayerCreationParams Constructor(Terrain)
A ArcGIS.Core.Data.Analyst3D.Terrain object.
Example
    Creates a parameter object with a ArcGIS.Core.Data.Analyst3D.Terrain.
    Syntax
    Public Function New( _
       ByVal terrain As Terrain _
    public TerrainLayerCreationParams(
       Terrain terrain
    Parameters
    terrain
    Example
    Create a TerrainLayer from a dataset
      var terrainCP_ds = new TerrainLayerCreationParams(terrain);
      terrainCP_ds.Name = "My Terrain Layer";
      terrainCP_ds.IsVisible = true;
      //Create the layer to the terrain
      // Note: Needs QueuedTask to run
        var terrainLayer_ds = LayerFactory.Instance.CreateLayer<TerrainLayer>(terrainCP_ds, map);
    Create a TerrainLayer with renderers
      var terrainCP_renderers = new TerrainLayerCreationParams(terrain);
      terrainCP_renderers.Name = "My LAS Layer";
      terrainCP_renderers.IsVisible = true;
      // define the edge type renderer - use defaults
      var edgeRD = new TinBreaklineRendererDefinition();
      // define the face/surface renderer
      var faceRD = new TinFaceClassBreaksRendererDefinition();
      faceRD.ClassificationMethod = ClassificationMethod.NaturalBreaks;
      // accept default color ramp, breakCount
      // define the dirty area renderer - use defaults
      var dirtyAreaRD = new TerrainDirtyAreaRendererDefinition();
      // add renderers to dictionary
      var t_dict = new Dictionary<SurfaceRendererTarget, TinRendererDefinition>();
      t_dict.Add(SurfaceRendererTarget.Edges, edgeRD);
      t_dict.Add(SurfaceRendererTarget.Surface, faceRD);
      t_dict.Add(SurfaceRendererTarget.DirtyArea, dirtyAreaRD);
      // assign dictionary to creation params
      terrainCP_renderers.RendererDefinitions = t_dict;
        var terrainLayer_rd = LayerFactory.Instance.CreateLayer<TerrainLayer>(terrainCP_renderers, map);
    Requirements
    ArcGIS Pro version: 3.2 or higher.
