ArcGIS.Core.Data Namespace / Table Class / IsArchiveEnabled Method
    IsArchiveEnabled Method (Table)
    Gets a value indicating whether this table is archive-enabled. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    Public Function IsArchiveEnabled() As Boolean
    public bool IsArchiveEnabled()
    Return Value
    false if this table is not archive-enabled or does not support archiving; otherwise, true.
    Exceptions
    ExceptionDescription
    A geodatabase-related exception has occurred.
    Requirements
