ArcGIS.Core.Data.Mapping Namespace / DimensionFeature Class / GetUseCustomLength Method
    Gets if the dimension feature is using the custom length. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    Public Function GetUseCustomLength() As Boolean
    public bool GetUseCustomLength()
    Return Value
    true if using custom length; otherwise, false.
    Exceptions
    ExceptionDescription
    A geodatabase-related exception occured.
    Requirements
