ArcGIS.Core.Data.Mapping Namespace / DimensionFeature Class / SetUseCustomLength Method
A boolean to use the custom length for the feature.
    Sets if the dimension feature is using the custom length. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    Public Sub SetUseCustomLength( _
       ByVal useCustomLength As Boolean _
    public void SetUseCustomLength(
       bool useCustomLength
    Parameters
    useCustomLength
    Exceptions
    ExceptionDescription
    A geodatabase-related exception occured.
    Requirements
