ArcGIS.Core.Geometry Namespace / IGeometryEngine Interface / GetPointsAtM Method
The multipart from which the locations will be extracted.
The M-value to locate.
The lateral offset of the output points.
Example
    GetPointsAtM Method (IGeometryEngine)
    Gets a multipoint corresponding to the locations along the multipart where the specified M-value occurs. Coordinates/measures are interpolated when appropriate.
    Syntax
    Function GetPointsAtM( _
       ByVal multipart As Multipart, _
       ByVal mValue As Double, _
       ByVal offset As Double _
    ) As Multipoint
    Parameters
    multipart
    mValue
    offset
    Return Value
    Multipoint representing the locations found. If the input multipart is empty, an empty multipoint is returned.
    Exceptions
    ExceptionDescription
    Multipart is null or empty.
    This geometry is not M-Aware.
    Spatial reference of multipartis an image coordinate system.
    Example
    Get a multipoint corresponding to the locations where the specified M values occur along the geometry - GetPointsAtM
      string json = "{\"hasM\":true,\"paths\":[[[-3000,-2000,10],[-2000,-2000,15],[-1000,-2000,20],[0,-2000,0],[1000,-2000,20],[2000,-2000,30],[3000,-2000,10],[4000,-2000,5]]],\"spatialReference\":{\"wkid\":3857}}";
      polyline = PolylineBuilderEx.FromJson(json);
      Multipoint multipoint = GeometryEngine.Instance.GetPointsAtM(polyline, 10, 500);
      // multiPoint.PointCount = 4
      // multipoint.Points[0]  X= -3000, Y= -2500  M= 10
      // multipoint.Points[1]  X= -500, Y= -2500  M= 10
      // multipoint.Points[2]  X= 500, Y= -2500  M= 10
      // multipoint.Points[3]  X= 3000, Y= -2500  M= 10
    Requirements
