ArcGIS.Core.Geometry Namespace / GeometryEngine Class / GetMinMaxM Method
The multipart from which the M-values are extracted.
The minimum M-value.
The maximum M-value.
Example
    GetMinMaxM Method (GeometryEngine)
    Gets the minimum and maximum M-value.
    Syntax
    Public Sub GetMinMaxM( _
       ByVal multipart As Multipart, _
       ByRef minM As Double, _
       ByRef maxM As Double _
    public void GetMinMaxM(
       Multipart multipart,
       out double minM,
       out double maxM
    Parameters
    multipart
    minM
    maxM
    Exceptions
    ExceptionDescription
    Multipart is null.
    This geometry is not M-Aware.
    Spatial reference of multipartis an image coordinate system.
    Example
    Get the minimum and maximum M values - GetMinMaxM
      string json = "{\"hasM\":true,\"rings\":[[[-3000,-2000,10],[-2000,-2000,15],[-1000,-2000,20],[0,-2000,0],[1000,-2000,-20],[2000,-2000,-30],[3000,-2000,10],[4000,-2000,5]]],\"spatialReference\":{\"wkid\":3857}}";
      polygon = PolygonBuilderEx.FromJson(json);
      GeometryEngine.Instance.GetMinMaxM(polygon, out double minM, out double maxM);
      // minM = -30
      // maxM = 20
      json = "{\"hasM\":true,\"paths\":[[[-3000,-2000,10],[-2000,-2000,null],[-1000,-2000,null]]]}";
      polyline = PolylineBuilderEx.FromJson(json);
      GeometryEngine.Instance.GetMinMaxM(polyline, out minM, out maxM);
      // minM = 10
      // maxM = 10
      json = "{\"hasM\":true,\"paths\":[[[-3000,-2000,null],[-2000,-2000,null],[-1000,-2000,null]]]}";
      // minM = double.Nan
      // maxM = double.Nan
    Requirements
