ArcGIS.Core.Data Namespace / BimFileDatastore Class / GetConnector Method
    GetConnector Method (BimFileDatastore)
    Gets the Connector associated with the currently opened BIM file data store. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    Public Overrides NotOverridable Function GetConnector() As Connector
    public override Connector GetConnector()
    Return Value
    The Connector associated with the currently opened BIM file data store.
    Exceptions
    ExceptionDescription
    A geodatabase-related exception has occurred.
    Requirements
    ArcGIS Pro version: 3.3 or higher.
