ArcGIS.Core.Data.LinearReferencing Namespace / LineEventInfo Class / LineEventInfo Constructor / LineEventInfo Constructor(Table,String,String,String,String)
The table that contains line events.
The name of the field that contains the route identifier associated with each event.
The name of the field that identifies where the event starts within the route.
The name of the field that identifies where the event ends within the route.
The name of the field that identifies the offset of the line event from the underlying route.
Example
    Initializes a new instance of the PointEventInfo class with an offset field.
    Syntax
    Parameters
    lineEventTable
    routeIDFieldName
    fromMeasureFieldName
    toMeasureFieldName
    offsetFieldName
    Exceptions
    Example
    Create a RouteEventSource via dynamic segmentation process for line events
      static void CreateLineEventSource(Geodatabase geodatabase, string routeFeatureClassName = "Roads", string eventTableName = "Accidents", string routeIdFieldName = "RID", string toMeasureFieldName = "toMeasure", string fromMeasureFieldName = "fromMeasure", string offsetFieldName = "Offset")
        using (FeatureClass routesFeatureClass = geodatabase.OpenDataset<FeatureClass>(routeFeatureClassName))
        using (Table eventsTable = geodatabase.OpenDataset<Table>(eventTableName))
          RouteInfo routeInfo = new RouteInfo(routesFeatureClass, routeIdFieldName);
          EventInfo eventInfo = new LineEventInfo(eventsTable, routeIdFieldName, fromMeasureFieldName, toMeasureFieldName, offsetFieldName);
          RouteEventSourceOptions routeEventSourceOptions = new LineEventSourceOptions() { IsPositiveOffsetOnRight = true };
          using (RouteEventSource routeEventSource = new RouteEventSource(routeInfo, eventInfo, routeEventSourceOptions))
          using (RouteEventSourceDefinition routeEventSourceDefinition = routeEventSource.GetDefinition())
            // Locating errors
            IReadOnlyList<RouteEventSourceError> errors = routeEventSource.GetErrors();
            // Route event source fields
            IReadOnlyList<Field> routeEventSourceFields = routeEventSourceDefinition.GetFields();
            // Add RouteEventSource to the ArcGIS Pro map
            FeatureLayerCreationParams layerParams = new FeatureLayerCreationParams(routeEventSource)
              Name = "HighCrashAreas"
            LayerFactory.Instance.CreateLayer<FeatureLayer>(layerParams, MapView.Active.Map);
    Requirements
    ArcGIS Pro version: 3.3 or higher.
