ArcGIS.Core.Data.LinearReferencing Namespace / PointEventInfo Class / PointEventInfo Constructor / PointEventInfo Constructor(Table,String,String,String)
The table that contains point events.
The name of the field that contains the route identifier associated with each event.
The name of the field containing the measure value associated with the point event.
The name of the field that identifies the offset of the point event from the underlying route.
Example
    Initializes a new instance of the PointEventInfo class with an offset field.
    Syntax
    Parameters
    pointEventTable
    routeIDFieldName
    measureFieldName
    offsetFieldName
    Exceptions
    Example
    Create a RouteEventSource via dynamic segmentation process for point events
      static void CreatePointEventSource(Geodatabase geodatabase, string routeFeatureClassName = "Roads", string eventTableName = "Accidents", string routeIdFieldName = "RID", string measureFieldName = "Measure")
        using (FeatureClass routesFeatureClass = geodatabase.OpenDataset<FeatureClass>(routeFeatureClassName))
        using (Table eventsTable = geodatabase.OpenDataset<Table>(eventTableName))
          RouteInfo routeInfo = new RouteInfo(routesFeatureClass, routeIdFieldName);
          EventInfo eventInfo = new PointEventInfo(eventsTable, routeIdFieldName, measureFieldName);
          RouteEventSourceOptions routeEventSourceOptions = new PointEventSourceOptions(AngleType.Tangent)
          { ComplementAngle = true };
          using (RouteEventSource routeEventSource = new RouteEventSource(routeInfo, eventInfo, routeEventSourceOptions))
          using (RouteEventSourceDefinition routeEventSourceDefinition = routeEventSource.GetDefinition())
            // Locating errors
            IReadOnlyList<RouteEventSourceError> errors = routeEventSource.GetErrors();
            // Route event source fields
            IReadOnlyList<Field> routeEventSourceFields = routeEventSourceDefinition.GetFields();
            // Add RouteEventSource to the ArcGIS Pro map
            FeatureLayerCreationParams layerParams = new FeatureLayerCreationParams(routeEventSource)
              Name = "RoadAccidents"
            LayerFactory.Instance.CreateLayer<FeatureLayer>(layerParams, MapView.Active.Map);
    Requirements
    ArcGIS Pro version: 3.3 or higher.
