ArcGIS.Desktop.Mapping Namespace / ExportFileOptions Enumeration
Example Example
    Specifies the different output file options for map series export.
    Syntax
    Members
    MemberDescription
    ExportAsSinglePDF Export the set of pages to a single, multi-page PDF.
    ExportMultipleNames Export each map series page to an individual file using the map series page name as a suffix.
    ExportMultipleNumbers Export each map series page to an individual file using the map series page number as a suffix.
    Example
    Export a map series to single PDF
      //Export a map series with multiple pages to a single PDF.
      string filePath = @"Path and file name for the output export file";
      //Create PDF format with appropriate settings
      PDFFormat MS_PDF = new PDFFormat()
        OutputFileName = filePath,
        Resolution = 300,
        DoCompressVectorGraphics = true,
        DoEmbedFonts = true,
        HasGeoRefInfo = true,
        ImageCompression = ImageCompression.Adaptive,
        ImageQuality = ImageQuality.Best,
        LayersAndAttributes = LayersAndAttributes.LayersAndAttributes
      //Set up map series export options
      MapSeriesExportOptions MS_ExportOptions = new MapSeriesExportOptions()
        ExportPages = ExportPages.Custom,  //Provide a specific list of pages
        CustomPages = "1-3, 5",  //Only used if ExportPages.Custom is set
        ExportFileOptions = ExportFileOptions.ExportAsSinglePDF,  //Export all pages to a single, multi-page PDF
        ShowSelectedSymbology = false  //Do no show selection symbology in the output
      //Export on the worker thread
      //Note: Must be on QueuedTask.Run
      //Check to see if the path is valid and export
      if (MS_PDF.ValidateOutputFilePath())
        layout.Export(MS_PDF, MS_ExportOptions);  //Export to PDF
    Export a map series to individual TIFF files
      //Export each page of a map series to an individual TIFF file.
      //Create TIFF format with appropriate settings
      TIFFFormat TIFF = new TIFFFormat()
        Resolution = 300,
        ColorMode = TIFFColorMode.TwentyFourBitTrueColor,
        HasGeoTiffTags = true,
        HasWorldFile = true,
        ImageCompression = TIFFImageCompression.LZW
      MapSeriesExportOptions MSExportOptions_TIFF = new MapSeriesExportOptions()
        ExportPages = ExportPages.All,  //All pages
        ExportFileOptions = ExportFileOptions.ExportMultipleNames,  //Export each page to an individual file using page name as a suffix.
        ShowSelectedSymbology = true  //Include selection symbology in the output
      //Note: Must be on the QueuedTask.Run()
      if (TIFF.ValidateOutputFilePath())
        layout.Export(TIFF, MSExportOptions_TIFF);  //Export to TIFF
    Inheritance Hierarchy
    System.Object
       System.ValueType
          System.Enum
             ArcGIS.Desktop.Mapping.ExportFileOptions
    Requirements
