ArcGIS.Core.Data.NetworkDiagrams Namespace / NetworkDiagram Class / GetFeatureAttributes Method / GetFeatureAttributes(DiagramElementSelection,String[],Boolean,Boolean) Method
The DiagramElementSelection to select the diagram elements to get attributes from.
Array of field names or alias names for the attributes to query in network source tables. Use keywords "SHAPE_Length" and "SHAPE_Area" to query shape length and shape area in any geodatabase. Use keywords "DiagramElement::SourceID" and "DiagramElement::Subtype" to query these attributes that are not in network source tables. Returned values for "DiagramElement::Subtype" 1 = standard element 2 = reduction junction 3 = connectivity association 4 = structural attachment 5 = reduction edge
Indicates whether to include attribute values for aggregated elements.
Indicates whether to use coded value names when returning attribute values.
    Get feature attributes of elements and aggregations of this network diagram. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    Parameters
    selection
    attributeNames
    addAggregatedElementValues
    useCodedValueNames
    Return Value
    Exceptions
    ExceptionDescription
    A geodatabase-related exception has occurred.
    Requirements
    ArcGIS Pro version: 3.3 or higher.
