Public Function ExtrapolateMs( _ ByVal multipart As Multipart, _ ByVal extrapolateMethod As ExtrapolateMMethod, _ ByVal startPartIndex As Integer, _ ByVal startPointIndex As Integer, _ ByVal endPartIndex As Integer, _ ByVal endPointIndex As Integer _ ) As Multipart
public Multipart ExtrapolateMs( Multipart multipart, ExtrapolateMMethod extrapolateMethod, int startPartIndex, int startPointIndex, int endPartIndex, int endPointIndex )
Parameters
- multipart
- The multipart to copy and update.
- extrapolateMethod
- The method to use when extrapolating the M-values. For example, if set to ExtrapolateMMethod.ExtrapolateBefore, then only the points before the start point of the range will be updated.
- startPartIndex
- The index of the part which contains the start point of the extrapolate range.
- startPointIndex
- The index of the start point of the extrapolate range. The index is relative to the start part.
- endPartIndex
- The index of the part which contains the end point of the extrapolate range.
- endPointIndex
- The index of the end point of the extrapolate range. The index is relative to the end part.
Return Value
An updated version of the input multipart.
