ArcGIS.Core.Geometry Namespace / GeometryEngine Class / SetMsAsDistance Method / SetMsAsDistance(Multipart,AsRatioOrLength) Method
The multipart in which to set the M-values.
Indicates whether the M-values are set as lengths or ratios along the multipart.
Example
    Sets the M-values to the cumulative length from the start of the multipart.
    Syntax
    Public Overloads Function SetMsAsDistance( _
       ByVal multipart As Multipart, _
       ByVal asRatioOrLength As AsRatioOrLength _
    ) As Multipart
    Parameters
    multipart
    asRatioOrLength
    Return Value
    Multipart with M-values set. If the input multipart is empty, then it is returned unchanged.
    Exceptions
    ExceptionDescription
    Multipart is null.
    This geometry is not M-Aware.
    Example
    Set the M-values to the cumulative length of the start of the multipart - SetMsAtDistance
      string json = "{\"hasM\":true,\"paths\":[[[-3000,-2000,1],[-2000,-2000,2],[-1000,-2000,3],[0,-2000,null],[1000,-2000,4],[2000,-2000,5],[3000,-2000,10],[4000,-2000,11],[5000,-2000,12],[6000,-2000,13],[7000,-2000,14]]],\"spatialReference\":{\"wkid\":3857}}";
      polyline = PolylineBuilderEx.FromJson(json);
      Polyline outPolyline = GeometryEngine.Instance.SetMsAsDistance(polyline, AsRatioOrLength.AsLength) as Polyline;
      // The xy-coordinates don't change.
      // The M-values of the vertices in outPolyline are (x, y, m):
      // { 0, 1000, 2000, 3000, 4000, 5000, 6000, 7000, 8000, 9000, 10000 }
      json = "{\"hasM\":true,\"rings\":[[[0,0],[0,3000],[4000,3000],[4000,0],[0,0]]],\"spatialReference\":{\"wkid\":3857}}";
      polygon = PolygonBuilderEx.FromJson(json);
      Polygon outPolygon = GeometryEngine.Instance.SetMsAsDistance(polygon, AsRatioOrLength.AsLength) as Polygon;
      // The M-values of the vertices in outPolygon are (x, y, m): { 0, 3000, 7000, 10000, 14000 };
    Requirements
    ArcGIS Pro version: 3.3 or higher.
