ArcGIS.Core.Geometry Namespace / IGeometryEngine Interface / ExtrapolateMs Method
The multipart to copy and update.
The method to use when extrapolating the M-values. For example, if set to ExtrapolateMMethod.ExtrapolateBefore, then only the points before the start point of the range will be updated.
The index of the part which contains the start point of the extrapolate range.
The index of the start point of the extrapolate range. The index is relative to the start part.
The index of the part which contains the end point of the extrapolate range.
The index of the end point of the extrapolate range. The index is relative to the end part.
Example
    ExtrapolateMs Method (IGeometryEngine)
    Extrapolates the M-values based on the extrapolate range defined by the input indices.
    Syntax
    Parameters
    multipart
    extrapolateMethod
    startPartIndex
    startPointIndex
    endPartIndex
    endPointIndex
    Return Value
    An updated version of the input multipart.
    Exceptions
    ExceptionDescription
    The input multipart is null.
    The HasM property of the input multipart is set to false.
    Spatial reference of multipartis an image coordinate system.
    startPartIndex or startPointIndex or endPartIndex or endPointIndex is negative.
    endPartIndex is less than startPartIndex.
    The extrapolation range is invalid.
    startPartIndex or endPartIndex is greater than or equal to the number of parts in the multipart.
    startPointIndex or endPointIndex is greater than or equal to the number of points in the specified part.
    Example
    Extrapolate M-values based on a range defined by part and vertex indices - ExtrapolateMs
      string json = "{\"hasM\":true,\"paths\":[[[2,0,50],[2,1,40],[3,1,30],[3,5,60],[7,5,12],[7,1,20],[9,1,28],[9,3,10]]],\"spatialReference\":{\"wkid\":4326}}";
      polyline = PolylineBuilderEx.FromJson(json);
      // Extrapolate M-values from part 0, point 3 to part 0, point 5
      Polyline outPolyline = GeometryEngine.Instance.ExtrapolateMs(polyline, ExtrapolateMMethod.ExtrapolateBefore, 0, 3, 0, 5) as Polyline;
      // The points in outPolyline are (x, y, m):
      // ( 2, 0, 90 ), ( 2, 1, 85 ), ( 3, 1, 80 ), ( 3, 5, 60 ), ( 7, 5, 12 ), ( 7, 1, 20 ), ( 9, 1, 28 ), ( 9, 3, 10 )
      json = "{\"hasM\":true,\"paths\":[[[2,0,50],[2,1,40],[3,1,30],[3,5,60],[7,5,12],[7,1,20],[9,1,28],[9,3,10]],[[5,-4,-10],[5,-2,-40],[10,-2,-60],[10,-6,-50],[8,-6,-40],[8,-4,-80],[6,-4,-90]]],\"spatialReference\":{\"wkid\":4326}}";
      // Extrapolate M-values from part 0, point 5 to part1, point 1
      outPolyline = GeometryEngine.Instance.ExtrapolateMs(polyline, ExtrapolateMMethod.ExtrapolateAfter, 0, 5, 1, 1) as Polyline;
      // The points in part 0 of outPolyline don't change. They are (x, y, m):
      // ( 2, 0, 50 ), ( 2, 1, 40 ), ( 3, 1, 30 ), ( 3, 5, 60 ), ( 7, 5, 12 ), ( 7, 1, 20 ), ( 9, 1, 28 ), ( 9, 3, 10 )
      // The points in part 1 of outPolyline are (x, y, m):
      // ( 5, -4, -10 ), ( 5, -2, -40 ), ( 10, -2, -90 ), ( 10, -6, -130 ), ( 8, -6, -150 ), ( 8, -4, -170 ), ( 6, -4, -190 )
    Requirements
    ArcGIS Pro version: 3.3 or higher.
