ArcGIS.Desktop.Editing.Controls Namespace / TableControl Class / Select Method / Select(Int64,Boolean) Method
The row index or object id to select.
Indicates that the id is an object id, otherwise it is a row index.
    Selects a row in the table. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    public void Select(
       long id,
       bool idIsObjectId
    Public Overloads Sub Select( _
       ByVal id As Long, _
       ByVal idIsObjectId As Boolean _
    Parameters
    id
    idIsObjectId
    Exceptions
    ExceptionDescription
    Requirements
    ArcGIS Pro version: 3.3 or higher.
